what is the yellow plug under the inlet on s2 rst
Old Oct 24, 2006 | 07:42 PM
dubs's Avatar
dubs
Default what is the yellow plug under the inlet on s2 rst
any able to tell me what the yellow plug under the inlet at the back of the engine is for?? it was plugged into a brown sensor.cheers
Old Oct 25, 2006 | 04:02 PM
JamboRS's Avatar
JamboRS
focus rs 1672
all the sensors on the inlet are colour coded mate,brown plug to brown sensor,yellow plug to yellow sensor and blact to black and blue to blue
youve got the wrong plug on the sensor
cant mind off the top off my head what the plugs do but there water and air sensors i think
Old Oct 25, 2006 | 04:25 PM
DazC's Avatar
DazC
Brown is thermo time switch to control the cold start injector.
Yellow is the coolant temp sensor
Blue is the cold start injector
Black is the auxilliary air valve.
Old Oct 25, 2006 | 04:40 PM
SafeChav's Avatar
SafeChav
This seems to be happening for too often. That will of been causing you allsorts of problems
Old Oct 25, 2006 | 05:52 PM
dubs's Avatar
dubs
i am well aware of the colour coding aspect i didnt plug the yellow to brown, the car is a bit of a dog and im slowly getting it to run better for my workmate, the guy he got it off had tampered with the meteringhead and the cold start valve had the black connector attached, this car has temp sender(green) in correct place, aux air valve(black) now in correct place and cold start(blue) in correct place, then there is tts valve(brown) with a yellow plug, there is no yellow senders nor is there brown plugs??? when you unplug the yellow from the brown the car runs like there is no boost?? rs manual i have for my s1 does not have a yellow?? so either some bawbag has minced up wiring somewhere or there is a yellow sensor wi a brown plug. any one know what happens when you disconnect the thermo time switch. cheers
Old Oct 25, 2006 | 06:23 PM
SafeChav's Avatar
SafeChav
Sorry mate i wasn't trying to say you had connected it up, just that its not right like that.
Just one thing:
A green plug on a S1???? The green sensor is a knock sensor only found on S2's.
All series 1's had the yellow plug for the CTS to start with, its common to brake over time, and could of been repaced with a different colour plug......
Old Oct 25, 2006 | 06:30 PM
DazC's Avatar
DazC
The CTS in under the manifold in the same area as the thermo time switch.
There should be no green plug and there should also be a brown for the thermo time switch.
Can you get any photos of the area and can you see if there is any wiring which has been cut back and taped up (possibly for the brown thermo time switch). Check that the green plug hasn't been peiced onto the wiring for the thermo time switch. Someone might have been bodging!!
Old Oct 25, 2006 | 06:48 PM
SafeChav's Avatar
SafeChav
DITTO
Baring in mind the yellow CTS is the hardest to get to as the plug is tucked right up under in the bottom side of the injector sandwich plate.
Old Oct 25, 2006 | 09:44 PM
dubs's Avatar
dubs
its a s2 im talking about???? also gen ford manual states: temperature sensor is green,thermo time switch is brown, now im totally lost, its time for a box of matches i think.
so what is the yellow plug for on a s2? mabye there has been mix matching between s1 and s2s here, what would the simtons be for thermo time switch not working?? or the cold start?? car will start 1st thing in the morn and run for 15 to 20 seconds then cut out, that makes me think the cold start may be working but tts may not.
Old Oct 25, 2006 | 11:32 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
I had a bit of bother wiring up my S1 to an S2 engine. . .seem to recall one plug was a diff colour to the sensor. . probably wired it up wrong tho
Old Oct 26, 2006 | 01:31 PM
SafeChav's Avatar
SafeChav
Absolutely DEFINATELY 100%, S1 or S2, the colours are:
CTS = Yellow
Thermo Time Switch = Brown
Cold start Injector = Blue
Auxiliary Air Device = Black
Knock Sensor = Green (S2 only)
2nd CTS = White (same shape as the fan sender) (S2 only)
If you're really having problems you may have to resort to tracing wire colours and continuity testing
Old Oct 26, 2006 | 05:05 PM
TURBO BOI's Avatar
TURBO BOI
this help
Old Oct 26, 2006 | 06:23 PM
dubs's Avatar
dubs
erm thats green on this car with a green plug?????????????? there is no brown plug at all. looks like a bodge so i will have to do a colour trace on the wiring instead
Old Oct 26, 2006 | 07:03 PM
SafeChav's Avatar
SafeChav
Ive modded the diagram to show where the brown sensor should be (Thermo Time Switch), and the CTS is Yellow and in the correct place.
Anything other than how its pictured, is WRONG
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
