Snapped bolts in head!
While changing my thermostat I have managed to snap 2 of the bolts that hold the housing on
They have snaped clean off and there is nothing at all that I can grip.
It is a CVH
any ideas?
It is a CVH
any ideas?
LOL, On one bolt the car louses all its water in 5 secs
Should I just put the car in the garrage and leave it until next show session?
What do you gugs think of this
http://www.toolsnextday.ltd.uk/Helic...icoil_kits.htm
As I have also stuffed the thread!
I wouldnt drill it out as you risj damaging the thread. Buy some left hand threaded easy outs. I bought a set of them and they're awesome. Cheap to, I think a set was less than a tenner.
Yes you can but i'd try & take the old one's out propperly first mate. Summat simillar happened to me once & i had to score the end of the remainder of the bolts just enough to unscrew them out with a screwdriver. It took ages but i got it done
If theres enough thread showing, why not use the 2 nut trick???
Scew on 2 nuts tight, then use the first nut you put on to get the sheard thread out.
it won't move as the top nut dont let it....................
But you've probalby tried that thinking about...
Mate drill small hole in centre of the snapped bolts then use these to get it out
http://www.machinemart.co.uk/product.asp?p=040213030
Then use these to re-tap thread
http://www.machinemart.co.uk/product.asp?p=040210303
Matt.
Matt.
easy out will be the best option,drill a small hole in the centre of the snapped stud so the easy out has got something to bite into,if you aint got a set pm me your address and i will post you my set and you can return them when you have finished.should only cost £1 to post.
cheeRS gary
AKA shrek
cheeRS gary
AKA shrek
this is now the problem
it has snapped clean off at the surface of the head!
The bolt at the top seams to work
The one on the side just spins
All the bolts don't go right through to the head, and there is lots of room, so it should be do-able in situe.
How do you get a M8 bolt out? seams a bit small to drill?
lol! I would have come round & helped out but im abit out the way form you............................................... ..B'HAM to be exact! pmsl
