Mfi injector upgrade?
Just wondered if there is any upgrade from the standard injectors on the mfi system? I know the best way would be to convert to efi or run a 5th injector but i was just curious to know?. Some guy was claiming he was running bigger jets on a zvh conversion running the mfi system
you can do it - but there is little point
The std items can flow all the fuel you need, the problem is metering such large amounts of fuel correctly. This is where an Mf2 comes into its own.
Just to point out - if u had a race only car - then you could use the bigger injectors. It would run very rich off boost, but thats not an issue when ur flat out all the time.
sadly, mine has them, and a machined fuel head, runs rich as fuck off boost, but is cooping with 1.5 bar held boost, and a peak of 1.8 on a t34 turbo, wil little fueling problems,
bloody lagy though
bloody lagy though
mk3ste
Oct 17, 2021 10:09 AM
Do you know if the injectors off the rs is the same as the xr3i?
