i was wondering what nuts to use on the 17 inch diamond cut rs wheels. i'm putting them on my rs turbo but the standard turbo bolts i feel are not big enough around the collar part. i put one of my dads focus nuts in the whole and the collars are a lot bigger so was wondering if there are wheel bolts out there that are ford fitting but with the larger heads/collars
The wheel nuts i have for my rims have little collars that slide over the nuts to suit the larger collars. I recon thats what you need m8. Not shure where you get them from?
