Turbo question?
Old Oct 23, 2006 | 07:58 PM
cosrep's Avatar
cosrep
Default Turbo question?
If I take the front compressor housing off will it mess up the balancing of the turbo?
Similarly if I take off the rear turbine housing will it mess up the balancing?
Old Oct 23, 2006 | 08:07 PM
trevCOSS's Avatar
trevCOSS
no and no, it will be fine
Old Oct 26, 2006 | 05:47 PM
melzieann's Avatar
melzieann
as above, just make sure you dont catch the blades
Old Oct 26, 2006 | 06:48 PM
B11GNS's Avatar
B11GNS
before you remove it though i would mark it up so that it goes back exactly the same way
Old Oct 26, 2006 | 10:57 PM
m_nettleship's Avatar
m_nettleship
can I swap, my standard excaust housing for a .63, without messing with the balancing or is there alot more to it than that.
Old Oct 27, 2006 | 12:17 AM
jon@work's Avatar
jon@work
yes - straight swap (but will the ECU map be OK?)
Old Oct 27, 2006 | 01:56 AM
m_nettleship
think so, 803s 3 bar map, stage three chip
Old Oct 27, 2006 | 05:51 AM
B11GNS's Avatar
B11GNS
You are going to give yourself a lot of lag, if your running greens the .48 should be fine and a lot less laggy
Old Oct 27, 2006 | 11:58 AM
TurboShed's Avatar
TurboShed
Cossiemodo
I think you would also experience some loss of power with the housings removed.
Matt Baxter
Sep 16, 2015 08:30 PM
s1turboman
Aug 29, 2015 04:27 PM
Marcus L
Aug 29, 2015 02:18 PM
A.t.p
Aug 15, 2015 11:37 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
