BREAKING TODAY,EX WORKS GROUP A ESCORT COSWORTH.
today ive decided iam going to dismantle my own escort so all parts are available.
will update with a list through the day and any parts will require a deposit to secure them,
as iam sure many of you are aware this is all the top quality stuff so please no messers or timewasters.
FFD 7 SPEED GEARBOX WITH HANDBRAKE RELEASE REMOTE OIL TANK WITH PIPES AND BOTH PROPSHAFTS,OIL BREATHER BOTTLE,GEAR STICK AND ALLY CROSSMEMBER,£7,750
FFD FRONT 7.5" DIFF WITH MAG SUMP,NEW CWP,MINT,CROSS SHAFT,OIL BREATHER,£4,500
REAR 9" DIFF WITH BRAND NEW 4.4CWP AND FULL REBUILD £3,500
MOUNTUNE GROUP A ENGINE,JUST FULLY REBUILT 80 MILES AGO,MOUNTUNE CAMS,GROUP A POCKETED PISTONS THAT ARE NEW,GROUP A CONRODS,HIGH PRESSURE OIL PUMP,NEW,SOLID LIFTERS.IGNITION DRIVE ON CAM WITH SENSOR,£3,600
STEEL WORKS PEDDLE BOX,WITH CYLINDERS AND HYDRALIC CLUTCH PEDDLE.£390
GROUP A RADIATOR AND FAN,£400
GROUP A TRIMMED BODYSHELL,GSE LIGHTWEIGHT TARMAC, CORRECTLY BUILT,BONNET,DOORS,BUMPERS,SKIRTS,WORKS DASH WITH STACK GUAGES,909 HEADLIGHTS,ROOF VENTS,CARBON FLOOR TRIMS,SPOILERS,LIGHTWEIGHT WORKS CAR WIRING LOOM,£4,750
TITANIUM SHAFTED T34 ANTI LAG GROUP A TURBO,120 MILES FROM BRAND NEW,COST £2200, £1100.
FULLY REBUILT GROUP A T34 TURBO WITHOUT MARAM SHAFT,ZERO MILES,WITH WARRENTY, £650
LHD GROUP A STEERING RACK, £550
Originally Posted by Mark_1
pedalbox and type? hyd.clutch?
what sump is it and driveshafts in front?
what ratio of the rear diff?
what engine managment type and loom?
magnesium sump,group A shafts,
rear diff is 4.4.
T6 ecu with pectel loom.
Originally Posted by abdr500
TF Rallyesport
fook sake here we go .what does that mean.some people do convert the cars you no
Originally Posted by DazC
is it 2wd or 4x4
Tim said no messers first as well... and then the first post was that dumbass question
is it 2wd or 4x4
Originally Posted by NEEDFORSPEED
hi how much for f & r coilovers and any modyfing needed to fit 4x4 saph? cheers
Originally Posted by wayne thomas
Does this mean you've decided build the Focus simulator into a rally car then Tim?
DazC you can carry on laughing
Porkie
you dont no if am a messer do you
i am the one that was messed around DazC you can carry one laughig
i am the one that was messed around DazC you can carry one laughigYour Question was very stupid though if you think about it and a waste of Tims time. He also ask for no timewasters
The reason it was stupid is that Tim is very well known on here as a guy who not only breaks Rally cars but COMPETES successfully in them at top events. He stated he was breaking his own car and gave clear details of it.
As a Cosworth owner and a long term member of this site with over 2000posts to ask if this car was 2wd or 4wd was dumb. Sorry it that upsets you!
P.S BTTT for Tim
Originally Posted by NUTTIN RILLA
What kind of box is it mate, can you give me a price too
Thanks tiff, i wasnt aware of that, cheers anyway
