Recently built Maram shafted T34/0.63 THE REAL DEAL
Old Oct 22, 2006 | 05:59 PM
Damo V's Avatar
Damo V
Default Recently built Maram shafted T34/0.63 THE REAL DEAL
Advertising for a friend…….
Genuine Garrett T34 Turbocharger with a .63 exhaust housing.
This turbo was rebuilt only 3000 miles ago by Universal Turbos with a Maram 247 Shaft to run heavy ALS also added was a brand new .63 exhaust housing and a 360° Thrust Bearing. A new Garrett -34 Actuator fitted at the same time, which is included with the turbo.
This combination of turbo and actuator is very good for high boost and power capabilities. A Turbo of this spec fitted to a Cosworth for example could see up to around 400bhp and you can use Anti- Lag all day long without fear of melting the turbo.
For those who aren’t aware, new maram shafts are VERY expensive, circa £1200 just for the shaft, let alone the rest of the turbo.
In the time this turbo has been fitted to a car since rebuild. It has only been run at 1.8 bar of boost and -0.3 boost at idle when the mild ALS has been on and the highest EGT (Exhaust Gas Temperature) ever seen was only 860°c, even that was on over- run and not on boost. The pictures shown are when the turbo was new, so you can see everything was new and clean, but obviously the turbo has done 3000 miles now.
It will fit an RS Turbo with a small bit of fabrication needed for a custom made exhaust down pipe but it will bolt straight on to the exhaust manifold with no problems.
£1100 Delivered (within UK) OVVNO
Reply here or pm…….
Old Oct 30, 2006 | 06:33 PM
AndyRST's Avatar
AndyRST
I hear that theres a shortage of maram shafts at the moment, and this ones ready to go
Old Oct 30, 2006 | 10:22 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Default Re: Recently built Maram shafted T34/0.63 THE REAL DEAL
An excellent turbo for over 300bhp IMO.
Old Oct 31, 2006 | 08:07 PM
adamS2RST's Avatar
adamS2RST
This Tone's old turbo?
Old Oct 31, 2006 | 11:18 PM
AndyRST's Avatar
AndyRST
Who's Tone?
IainRS1700T
Sep 25, 2015 06:44 AM
marky_g
49
Sep 22, 2015 09:59 PM
rogerxr3i
Sep 13, 2015 06:56 PM
rsstav
Sep 7, 2015 04:43 AM
