REV COUNTER READING HALF AFTER COILPACK CONVERSION
Old Oct 22, 2006 | 09:23 AM
mark taylor's Avatar
mark taylor
Default REV COUNTER READING HALF AFTER COILPACK CONVERSION
CAN ANYONE POINT ME IN RIGHT DIRECTION.
DONE A COILPACK CONVERSION TO MY 3DR.WORKS FANTASTIC BUT REV COUNTER READING HALF.
IF YOU HAVE A 3DR. AND HAD THIS HAPPEN TO YOU AND FOUND A FIX PLEASE HELP ME.
TOOK A FRESH WIRE FROM PIN 21 TO BACK OF CLOCKS EXACTLY THE SAME[HALF REVS].THIS SHOWS WIRING IS OK.
WENT AND GOT ONOTHER DRIVER BOARD FITTED YESTERDAY FROM MSD STILL HALF REVS.[TOP GUYS AT MSD CHEERS STU AND KENNY].
PLEASE PLEASE HELP GUTTED.CHEERS MARK
Old Oct 22, 2006 | 10:21 AM
B11GNS's Avatar
B11GNS
Just get back to Stu, he'll be able to point you in the right direction.
Old Oct 29, 2006 | 10:30 AM
mark taylor
Default REV COUNTER
FINALLY GOT IT SORTED.
SENT MY REV COUNTER AWAY TO A COMPANY IN WEST YORKSHIRE,RE CALIBRATED IT TO RUN ON WASTED SPARK[WORKS FANTASTIC]I NEW THERE WAS NOTHING WRONG WITH THE WIRING TO MY REV COUNTER .SO IF YOU ARE CONTEMPLATING RUNNING COILPACK CONVERSION YOU WILL NEED TO SEND YOUR REV COUNTER AWAY TO GET DONE.MOD MIGHT WORK WITH SAFFS AND ESCORT COSWORTHS BUT DEFINATLY DOES NOT WORK WITH 3DRS[LINK WIRE ON BACK OF CLOCKS]AS 3DR REV COUNTERS ARE TOTALY DIFFERENT WORKINGS.
CHEERS MARK
Old Oct 29, 2006 | 10:35 AM
mark taylor
Default REV COUNTER
ANYONE WANT MORE INFO LOG ONTO.
WWW.JDO-INSTRUMENT-ENG.CO.UK
OR CALL HIM ON 01535 662701
CHEERS MARK
Old Oct 29, 2006 | 07:23 PM
bige's Avatar
bige
link not working
Old Oct 30, 2006 | 08:26 AM
sailorbob's Avatar
sailorbob
http://www.jdo1.com/
Old Nov 26, 2006 | 05:47 PM
tim10_10's Avatar
tim10_10
How much did the recalibration cost mark?
Old Nov 26, 2006 | 05:52 PM
Niall.b's Avatar
Niall.b
still having this prob with mine, still havent worked out if the rev counter wire should go to 1 or be split to go to both coils? any help?
Old Nov 26, 2006 | 06:32 PM
jon@work's Avatar
jon@work
if you've got the SECS/MSD board, then there should be a feed from ECU pin 21 that should go to the rev counter
Old Nov 26, 2006 | 07:44 PM
Niall.b's Avatar
Niall.b
aimt mate, got sm4 & 2 x coil packs
Old Nov 26, 2006 | 10:12 PM
foreigneRS's Avatar
foreigneRS
Testing the future
recalibration just involves changing a resistor
Rsmat
89
Oct 12, 2015 07:50 AM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
