missfire escort cosworth
Old Oct 21, 2006 | 04:05 PM
Hybrid-Chris's Avatar
Hybrid-Chris
Default missfire escort cosworth
I have a strange missfire.
So far i have changed the coil,plugs,phase sensor and crank sensor.
It only seems to be high boost when i have the missfire. If i turn the boost controller off i have no issue but even if the controller is on its lowest setting 0.95 bar it misses.
HKS EVC boost controller
Old Oct 22, 2006 | 08:53 AM
DENNIS's Avatar
DENNIS
get on the rollers, misfires on boost are bad news , the escort cossie has poor wiring to the fuel pump and can give low fuel pressure on boost ( make sure the RR can check your emissions on the rollers ) if it only happens on boost its going to be had to trace off boost.....
you have done the basics so get on the rollers
Old Oct 22, 2006 | 08:57 PM
Marc97's Avatar
Marc97
Sounds like an over boost valve kicking in. Standard boost will be less than 0.95 bar and I would imagine an overboost valve kicks in at 1 bar. Just sounds like its coming in a little earlier is all. There is some gadgetry that eliminates the over boost valve, I think its called a fuel cut defender????
Anyhowz, thats my pearl of wisdom from my non existent knowledge of cossies lol.
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
