Gearlinkage......
Old Oct 18, 2006 | 08:39 PM
ShandzS1's Avatar
ShandzS1
Default Gearlinkage......
i have a mk3 A-plate, came with 1.3 cvh 4-speed, i have put the 1.9 cvh with mk3 xr3i box in it, but cant seem 2 find gearlinkage that will fit the car to work the 5-speed, got mk4 gearlinkage but wont fit, dont have the holes in the tunnel, instead it has a cradle that holds it up from underneath. Any clues what mk3 has the gearlinkage i need??
Cheers Neil
Old Oct 19, 2006 | 09:34 AM
gary scott's Avatar
gary scott
You need an early MK3 one, a Y-reg XR3i with a 5 speed box or even an RS1600i will have the one your after.
Ive got a Y reg 3i and that has a five speed linkage in a cradle like you say.
I think a later one will fit but you will have to drill the four holes in the tunnel and bolt it up that way.
Gary
Old Oct 19, 2006 | 04:34 PM
ShandzS1's Avatar
ShandzS1
Cheers bud, got told to just drill holes in the tunnel, but id rather get the rite thing, i have a S1 and its the same as mk4, well if u here any 1 with the proper gearlinkage giv us a shout!!
Neil
Old Oct 22, 2006 | 10:48 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Oi Oi....
The best linkage to use for this setup is off a puma
Lookski here for info.
http://oddkiddcreations.co.uk/forum/index.php
Old Oct 23, 2006 | 06:05 PM
ShandzS1's Avatar
ShandzS1
What puma? would it be better than the proper cradle type?
Old Oct 24, 2006 | 08:59 PM
Versus_Creations
Ask me a question!
The cradle is shite
Just use some decent studs with a puma linkage as the linkage has a rubber mount. You will see what i mean when you look at one.
