Cossie ABS Wiring Help
Old Oct 18, 2006 | 05:51 PM
ando4i's Avatar
ando4i
Default Cossie ABS Wiring Help
Hi
Anyone know where these coloured wires go on the ABS system, I'm stripping it out and tracing the wires back and 3 are doing my head in.
Blue and Black goes into the main loom and towards the fuse box. But looking in the fuse box, there is no fuse for the ABS.
Black Quite thick goes the same way, is this a Negative?
Green and Brown goes into the speedo and rev counter console Multiplug and mates to another same colour wire, fourth from the right.
Any clues would be great.
Mark.
Old Oct 19, 2006 | 05:08 PM
velocity's Avatar
velocity
blue and black has a 12v supply that originates from fuse 22 initally as a black and green wire and goes to the abs warning indicator in the dash( its the amber one with the car skidding on it)
the black wire begins as a black and yellow wire and is a 12v from the ignition switch on position it changes to a full black wire at junction s-1076, it powers abs pump relays number 2 and also goes to pin 2 of the abs ecu.
the green and brown wire is actually comming from the dash cluster from one side of the brake warning light on its way to the abs diagnostic plug beside the abs module.the other side of the brake warning light is supplied with 12v from a junction with the blue and black wire mentioned above
if you want a wireing diagram, pm me an email and i will send you one
Old Oct 20, 2006 | 11:11 AM
ando4i's Avatar
ando4i
Thanks Very Much
PM Sent
Mark.
Old Oct 20, 2006 | 04:14 PM
velocity's Avatar
velocity
email sent
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
155lee
Sep 23, 2015 01:27 PM
jay030787
Sep 18, 2015 04:38 PM
