COSSY throttle question ???
Old Oct 17, 2006 | 09:59 AM
neil d's Avatar
neil d
Default COSSY throttle question ???
Just trying to find out if there is a setting on the throttle butterfly that u set just to allow air in on tickover or is it just closed ??? having trouble with C/O so going back to basics
Old Oct 17, 2006 | 11:20 AM
Dave Henshall's Avatar
Dave Henshall
you can ajust the idle screw under the butterfly which basically does that and lets more air though - but as a result does increaser the idle speed - as you'd expect. you can ajust the cable to actually hold the butterfly open but his isnt recommended, i think what you need to do is ajust the CO ajustment screw on the ecu, it s small pot that can be ajusted to do exactly what you want
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
mike elsome
Sep 14, 2015 04:08 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
Marino
Sep 12, 2015 11:10 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
