can you fit an xr3i/rs1600i inlet???
Old Oct 16, 2006 | 08:11 PM
scotty86d's Avatar
scotty86d
Default can you fit an xr3i/rs1600i inlet???
can one run an xr3i/rs1600i inlet manifold on an mfi rst ok without probs, ie does iot fit. obviously a new intercooler pipe nees to be joined and im assuming acouple of bits of samco and a long pipe shud do it. just think it may help with act's and just look a bit different.
Old Oct 16, 2006 | 08:13 PM
Rick's Avatar
Rick
wont make a bit of difference to temps mate.
Old Oct 16, 2006 | 09:57 PM
scotty86d's Avatar
scotty86d
does it have a better flow inside it or is the standard jobby better. just think it would look quite diffferent too.
Old Oct 17, 2006 | 03:32 PM
MarkXr's Avatar
MarkXr
I've built a 2.0 ZVH turbo with a RSi manifold.
Not for lower ACT's or better flow but for a different look and most of all because this way I can use the RSi cam cover........
Car doesn't run yet but I've seen a couple of examples like this at the shows.
Use an RSi inlet, the throttle body bolts line up with the turbo throttle body, the 3i one is different! Also the 3i throttle body is placed on the inlet at an angle which makes it more difficult to create a cross over pipe from I/C to throttle body......
Hopefully this helps you out a bit.
XR/RS-Greetz,
Mark
Old Oct 17, 2006 | 04:43 PM
XR2's Avatar
XR2
There's no proof if it's better or not, but it's different!
RUBY123
Oct 22, 2023 12:04 PM
Danielbetty
Oct 3, 2015 06:01 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
Cosnada
Aug 27, 2015 09:15 AM
Aug 20, 2015 09:21 PM
