Buzzing on Fiesta front light cluster
Old Oct 15, 2006 | 05:57 PM
Phil M's Avatar
Phil M
Default Buzzing on Fiesta front light cluster
On my daughter's 51 plate Fiesta the nearside light cluster has a buzzing noise when you switch the side lights on.
Investigating the problem there appears to be a green multi plug for the power which could also be a relay?
Has any had this problem ?...is there a relay in these Bosch lights ? can it be replaced or is it a new light cluster?...thanks Phil M
Old Oct 15, 2006 | 07:00 PM
DazC's Avatar
DazC
If it's a relay then it is possible that the conacts have worn and aren't making proper contact causing the buzzing.
I am not sure if they can be replaced to be honest.
Old Oct 15, 2006 | 08:26 PM
Phil M's Avatar
Phil M
Thanks....I think a new light cluster is required to stop this noise....Phil M
Botts
Aug 13, 2015 04:16 PM
turbobill
Aug 1, 2015 08:55 PM
Old ford
Jul 31, 2015 06:50 AM
