saff cos problem
Old Oct 15, 2006 | 01:09 PM
pez's Avatar
pez
Default saff cos problem
hi,can anyone help? i have 4x4 saff cosworth,but the bag of spanners has no power 2 the fuel pump and the electric windows wont work.so far ive checked fuses,changed the fuel pump relay,cut out switch in the boot,put new wiring connections 2 the pump tested the pump direct 2 a battery,tried another ecu and had the immobiliser removed thinking that had packed up! any ideas?
Old Oct 15, 2006 | 09:12 PM
Daveesaunders's Avatar
Daveesaunders
My pump would come on one day when I had the light boards removed, turns out the bloody thing is earthed through one of them which I discovered after several hours of swearing and trying everything I could think. Doesn't explain the windows though.
Old Oct 17, 2006 | 06:35 PM
pez's Avatar
pez
thanx 4 ur reply mate,sorted the problem 2day.turns out it was just corrosion between the ignition relay and the fuse box.ive spet about 100 pound tryin 2 solve this fault!! thanx 4 ur help though
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
`spotty
Sep 25, 2015 11:41 PM
coscor86
Sep 20, 2015 01:21 PM
Rammer46
Sep 18, 2015 08:31 AM
Flateric_2002
Sep 15, 2015 08:41 AM
