ABS light is permanently on
Old Oct 11, 2006 | 09:25 PM
Maxxeh's Avatar
Maxxeh
Default ABS light is permanently on
What do you guys think the problem is.
Old Oct 11, 2006 | 10:32 PM
addiction's Avatar
addiction
either the abs belt has snapped or the sensors are faulty
Old Oct 11, 2006 | 10:35 PM
Maxxeh's Avatar
Maxxeh
will it not activate the abs? wud it be a big problem?
Old Oct 11, 2006 | 10:41 PM
addiction's Avatar
addiction
if the belt has snapped the abs will not work properly
Old Oct 11, 2006 | 10:44 PM
adamS2RST's Avatar
adamS2RST
IT'll fail MOT like that too
Old Oct 11, 2006 | 10:47 PM
addiction's Avatar
addiction
correctamundo
Old Oct 12, 2006 | 12:10 AM
Diamonds.'s Avatar
Diamonds.
take the abs out totally...
Old Oct 12, 2006 | 09:53 AM
Maxxeh's Avatar
Maxxeh
yea im in 2 minds of doing this. ive got front cosworth setup. Will it make a lot of difference?
Old Oct 12, 2006 | 04:34 PM
addiction's Avatar
addiction
bear in mind that removing the abs entails removing the modulators and replumbing the brake lines!! just removing the belts will only stop the abs from working! doin it properly will result in better pedal feel
Old Oct 12, 2006 | 09:40 PM
Maxxeh's Avatar
Maxxeh
do they lock up easier tho?
Old Oct 12, 2006 | 10:52 PM
scotty86d's Avatar
scotty86d
took my abs out and the brakes were fine. only thing i noticed was my back end stpeeing out braking hard from high speeds, prob just my crappy rear drums though. felt nice nonetheless to brake with. and gets rid of the shitty modulators which makes changing the gearbox easier!!!
Old Oct 13, 2006 | 05:05 PM
Maxxeh's Avatar
Maxxeh
does the ABS weigh a lot?
I was thinking of putting braided brake line and also ripping the abs out. Would the lights still be flashing once i take it out?
Old Oct 13, 2006 | 05:30 PM
addiction's Avatar
addiction
yes the light will still come on but is easy to bypass
Old Nov 28, 2006 | 09:58 PM
slimwynn's Avatar
slimwynn
how do u bypass it
Old Nov 28, 2006 | 10:09 PM
addiction's Avatar
addiction
either just tape the sensors up or remove them and rewire the plugs to make the connection
Old Nov 29, 2006 | 12:57 AM
lewis_lisa's Avatar
lewis_lisa
my light is always on and i have cossie brakes all round im not sure about the m.o.t thought as my abs is still fitted just no belts on it.
Old Nov 29, 2006 | 08:04 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
Or one of the sensors has fallen out of the housing.
Access is better underneath, but you can do it from the top if you're flexible If you look under the car & see something dangling, then I'm gonna guess it's one of the sensors. The fit into a small rectangle housing onto the abs belt (large oval shaped plastic cover with small rectangle hole)
Old Nov 29, 2006 | 06:05 PM
slimwynn's Avatar
slimwynn
i could just take the bulb out of the dash
muzzman1
Sep 30, 2015 08:59 PM
