cutting out when below half tank
Old Oct 11, 2006 | 08:52 AM
RodgeRS_Turbo's Avatar
RodgeRS_Turbo
Default cutting out when below half tank
me again! seems there was more problems than I thought with my first RS! when I go around a roundabout/sharp bend when under half a tank, the car cuts out and is a b*gger to start again. I was thinking that it was drawing air from somewhere, but it cant be a fuel line or it would be leaking fuel - which its not. Is the sender unit maybe not in correctly or something?
as always, thanks for any input.
Jamie
Old Oct 11, 2006 | 09:42 AM
adamS2RST's Avatar
adamS2RST
Are you certain your guage is accurate? Also, it may be the tank it'self, perhaps it doesn't have a swirl pot inside, just a couple more things to think about...
Old Oct 11, 2006 | 09:46 AM
RodgeRS_Turbo
ive changed the clocks twice to make sure its not the gauge
whats a swirl pot do? ive seen alot of polished/alloy swirl pots for sale, dont actually know its uses? cheers
Old Oct 11, 2006 | 10:10 AM
adamS2RST's Avatar
adamS2RST
No I am on about the one inside the fuel tank, it may depend on what fuel tank you are running but as I see it part of the design is to eliminate fuel starvation when going round corners etc.
Old Oct 11, 2006 | 12:00 PM
RodgeRS_Turbo
I see. So does all RSs come with a swirl pot as standard? I will taek the tank off and have a look, ive got a spare tank so if theres no swirl pot/fauty one ill replace it. where on the tank is it?
cheers
Old Oct 11, 2006 | 01:03 PM
Rab's Avatar
Rab
Fucking superstar........
The plastic swirl pot inside your tank is fucked. Basically you need a new petrol tank.
Old Oct 11, 2006 | 05:03 PM
HORNETS7's Avatar
HORNETS7
as above though somone might have swapped the tanks for a non rs tank sure all injection tanks have the swirl pot in though
Old Oct 16, 2006 | 11:12 PM
escortlad's Avatar
escortlad
just had this prob too mate,so i changed for another rs tank and sorted probs out,they have a swirl pot inside.Easy to change too
Nov 1, 2015 06:53 PM
mpilk
Sep 27, 2015 09:21 AM
