Brand new 2.1 zvh/zetec engine (sold)
Brand new block from ford never been run before
Brand new calibre turbo pistons (85.97mm)
Brand new piston rings
Reground crank to 0.25 on mains and big ends
Brand new main and big end bearings
Brand new ford oil pump
Brand new oil spray jets in block
Brand new engine gasket set
Zetec con rods
Arp con rod bolts
Modified sump with turbo oil return on front and breather pipe on rear
Brand new sump bung
This bottom end can be either a zvh just needs water pump plate for escort or fiesta or can be used as a turbo zetec engine the pictures below show that everything is new, pm me with any questions.
£1300 ono
Zetec con rods
Arp con rod bolts
Brand new sump bung
£1300 ono
