Sticking wastegate
As above, my exhaust note is very different along with a whooshing sound (like air escaping), but then suddenly goes. Guys at the rolling road place believe my wastegate is sticking a bit.
Is this an easy job to rectify, and could something else be causing it?
Cheers peeps.....
Cheers peeps.....
Cheers peeps.....
Cheers peeps.....
mine had a sticking waste gate not to long ago. normally with this you'll get loads of boost then nothing as it flys open and sticks. it then rattles as the vibrations slowly close it. mine was rectified by changing the wastegate housing. didn't do it myself. got harvey gibbs to do it when he set it up so not too sure on how hard it is to do or how long it takes.
Cheers peeps.....
Cheers peeps.....
Originally Posted by Turbo-Beal
Could it be off your boost guage?? Do you have one?? Might have a loose or split hose.
SMILER258
Sep 28, 2015 09:04 AM
