help what level ecu is this ??
Oct 5, 2006 | 11:11 PM
numbers say WD48.08/L3H.93
in the top right corner it says 048/01
thanks gys
paul
Oct 6, 2006 | 02:24 PM
Hi,
It's L8 from Sapphire 4wd with catalytic exhaust. (91 MY)
Regards
Claude
Oct 6, 2006 | 06:20 PM
will this be ok in a 2wd non cat ???
or will i have to mod it ?
Oct 6, 2006 | 08:32 PM
You will need a PF09 TPS Sensor and swap the two outer wires,also the chip will have to be changed depending on what spec you are running.
Last thing USE MOTORSPORT DEVELOPENTS CHIPS THERE GREAT!!!!!!!!!!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
griffo69
Oct 4, 2015 11:58 AM
IainRS1700T
Sep 25, 2015 06:44 AM
DixieTheKid
Sep 14, 2015 09:04 PM
