harsh throttle
Oct 5, 2006 | 10:17 PM
harsh throttle
hi guys, i got a problem. Wen im holding high revs, and slow easy of the throttle, me car jerks . Im pretty sure its not supposed to happen lol.
Oct 6, 2006 | 02:21 PM
Do you have a dump valve fitted?
Oct 6, 2006 | 03:54 PM
most likely to be the dump valve if you have one fitted when your coming off the boost
Oct 6, 2006 | 04:16 PM
do u suggets taking it off? what wud i replace it with, a recirc?
Oct 6, 2006 | 04:21 PM
Quote:
nothing!! just take it off and plug the hole with something! eg:broom handle or proper blanking bung
Oct 6, 2006 | 05:36 PM
thats not good for the turbo tho
Oct 6, 2006 | 08:17 PM
unless ur running big boost it makes sod all difference. The jerkyness is also due to the tps being a basically on off switch as well im pretty sure.
Oct 6, 2006 | 08:23 PM
how much is big boost? im running 19 psi. (well was
Oct 6, 2006 | 08:31 PM
loads of people dont use dump valves and im sure their turbos are fine to be honest.I will be taking mine off as soon as i go efi, get the chatter on the go, sounds a million times better.
Oct 6, 2006 | 10:59 PM
but mate, I heard that chatter is the turbo stalling.
Oct 7, 2006 | 11:43 AM
same but then again ive got friends with turbo cars and their turbos last ok given the abuse they get. I dont think its a big issue so long as the car has good oil and you tke reasonable care of the car
Oct 7, 2006 | 02:37 PM
u don't need it mate, from wot i gather the t3 turbo is tough as old boots if treated well and deosn't require a dump valve
mk3ste
Oct 17, 2021 10:09 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
mike elsome
Sep 14, 2015 04:08 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
