xr2i brakes
Old Oct 4, 2006 | 07:36 PM
robbob's Avatar
robbob
Default xr2i brakes
was out in my xr2i tonight when i noticed that my brake pedal was realy spongey then ther was hardley eny brakes at all what could be causing this
Old Oct 4, 2006 | 07:49 PM
Phil DJ's Avatar
Phil DJ
Low break pads or discs, air lock in the breaking system or could be something electrical to do with the ABS??
Hopefully not a fluid leak tho
Old Oct 4, 2006 | 07:57 PM
daveselwood's Avatar
daveselwood
Default brakes
check the level in your brake fluid resevoir if very low check for leeks
Old Oct 5, 2006 | 04:35 PM
Oranoco's Avatar
Oranoco
If there is plenty of fluid present I would be looking at the master cylinder.
Old Oct 5, 2006 | 04:50 PM
robbob's Avatar
robbob
just took the back drums off and noticed the shoes in bits that must be the problem then lol
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
