central locking gone wrong
Old Oct 4, 2006 | 03:37 PM
Tonyt1t's Avatar
Tonyt1t
Grey Mk4 Early XR3I
Default central locking gone wrong
ok u lot been a while since i had a problem lol was bound to happen sooner or later
found out why my central locking wasent working the person befor me had removed the fuse
so i put in a 15a fuse as recomended unlocked passenger door all opens nicely locked passenger door all now lock right i fort try drivers side jus to make sure its all working good
went to drivers side to unlock it made the noise then made the noise again tried the door and it had unlocked and re locked it self along with all other doors n boot so i went and unlocked it from passenger side all unlocked fine then tried to lock on the driver side and it done the noise twice again leaving the hole car open
any ideas what this could be?
Old Oct 4, 2006 | 04:45 PM
scottbrown's Avatar
scottbrown
usually its either the motor, or the wireing where it goes from the car to the door through the gromit. check wireing 1st then get to scrapper and get another motor to try
Old Oct 4, 2006 | 11:51 PM
Tonyt1t's Avatar
Tonyt1t
Grey Mk4 Early XR3I
ok thanks mate ill give her a go
Old Oct 5, 2006 | 12:37 AM
Diamonds.'s Avatar
Diamonds.
i think itll be the motor had the same problem
Old Oct 5, 2006 | 06:59 PM
HORNETS7's Avatar
HORNETS7
easiest thing to try first is spray wd40 on all the locks etc .....
some times if the catch cant be locked by the motor it unlocks as it think its got excessive resistance force!
Old Oct 12, 2006 | 10:06 AM
Tonyt1t's Avatar
Tonyt1t
Grey Mk4 Early XR3I
ok cheers bud
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
