aquamist water injection and SECS ecu monitor
Old Oct 4, 2006 | 09:24 AM
DamoM's Avatar
DamoM
Default aquamist water injection and SECS ecu monitor
Does anybody know which of aquamist water injection system will integrate with the ecu monitor? Aquamist say 'all of them' and PSI3 say that they don't know anything about Fords anymore!
Old Oct 4, 2006 | 07:52 PM
white4x4cos's Avatar
white4x4cos
Hi,I have aquamist 1s system on my car with pressure switch.
What i have done is take the 2 wires that normally goes to the pressure switch connect these to a 5 pole relais (30)&(87a).
Then take the wires from the secs monitor that control WI and connect them to relais (85)&(86) and job done
Hope this helps
Regards,
Johan.
Old Oct 5, 2006 | 02:35 PM
foreigneRS's Avatar
foreigneRS
Testing the future
secs monitor just has a switchable output that can be connected to a relay to do what you want with any WI system
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
griffo69
Oct 4, 2015 11:58 AM
