BONNET VENTS should u have a sheild if ya got a K&N?
i've fitted an induction kit to my saff cossie
its a foam pipercross grp A jobbie, popped the bonnet last week after it had been raining and all the water drips thru the bonnet vent straight onto it
it was soaking does that effect performance?
should i have a alloy shield fitted (like you do on the ERST when fitting an K&N)
ta
ta
the difference between the cos and an erst is that on the escort the filter is facing upwards so the water can go straight down into the metering unit, the saph has it on the side so it just goes straight thru it
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
