Heated front screen 4x4 saff
As it getting cold now i need to sort the front screen out on my other halfs saff, the switch is new(the little orange light does NOT come on when pressed
) the heated mirrors work ok when you push the switch but the front screen dont work atall ,and its a new screen???? So where do i look 1st to try and sort this out??? Any help anyone ???????
Oh the old screen did not work either
I know this is in the wrong section but not many people looks in the tech info!!
Originally Posted by xr4x4rs
check the relay and fuse for the screen mate
located nxt to the ecu behind the glovebox
its the black realy you want to find
Just been outside to have alook, can see 3 black plugs, think its a pink/red one millions of wires with fuses at the ends, all the fuses are ok !!!And all the plugs are connected
you need the engine running for the screen to work
it's normally a problem with the screen itself being fooked, but you can always test to see if there is power to it
you should also possibly have heated washer jets too, so see if these are ok as well
There are two relays for the front screen,one is now obsolete,i was lucky that the one fords had in stock was the one i needed,i had the same symptoms as you so fingers crossed you'll get it fixed m8.
Originally Posted by CosKev3
Should be able to hear the relay click when you press switch
As above though,check you have got power to the switch first
THANKS AGAIN
If it does turn out to be the relay has anyone got one they would sell??
the wires are in the engine bay for the screen aswell not the a pillars
just lift the bonnet and you will see 2 wires nxt to the hinges with heatshrink round them
Ok just been outside and removed the black relay ,the numbers on it are
77180
83BG14NO89CA
V23134-J4-X37
12V 70A
Can anyone tell me if this is the correct one please????
77180
83BG14NO89CA
V23134-J4-X37
12V 70A
it's a generic relay, just get one from any scrapy you are passing by and it'll fit
they are colour coded yellow, red, black, green, white, brown, blue etc etc so just dig ont out of a few fuse boxes
Oct 9, 2015 07:38 PM
mrmann
Aug 20, 2015 11:24 PM
track.focus'd
Aug 12, 2015 05:53 PM
