peugeot 306 GTI-6, worth buying
got the chance to buy a R-reg 306 GTI-6
has a blown head gasket & a fooked exhuast
only wants £350 for it, is it worth buying to make a bit of cash on
either fix it up or just sell it straight on via fleabay
nah im not sure, just what i've been told that its the head gasket by my mate. not even viewed the car as yet
mite pop round 2mora nite n av a scan
is there anyways of telling if its defo the headgasket?
Check the CO2 levels from the zorst - Check the oil see if there is any water in there - Usually the fans only blow either hot/cold not both.
Best bet would be to take a friend/mechanic of yours around with you and have a look - plus if its a mechanic he can tell you how much he would charge you at the sametime, this way you know what your dealing with straight away
I have a 306 S16 Great car same as the GTI 6 but with a 5 speed box
the only thing is the high ins grp
I have ment to have sold it by now lucky i have'nt as my mums using it as her car is playing up
timsrs
22
Sep 24, 2015 08:14 PM
cossie09
Sep 10, 2015 06:56 PM
