FAO MADROD
...what speed would i be goin with std rear diff ratio and std gearbox on 215/40/17 fronts and 235/40/17 rears at 7500rpm 7800rpm and 8000rpm
I assume my car could pull atleast 7500rpm in top!
7500 - 186
7800 - 194
8000 - 199
You have to factor in wind resistance and tyre resistance etc, so knock about 10 mph off those speeds for a truer indication.
7800 is a possibilty i'd say, more than that and you want solid lifters if holding for long periods.
I pulled 7600 in 5th at brunters, recorded 174 mph (smashed straight into the 7600 revlimiter
) and still had 1/4 mile to go on my T4 / 8 greens engine, but 4x4, in the rain.
So 2wd in the dry with 100 more bhp and you'd hit 7800 no probs!
) and still had 1/4 mile to go on my T4 / 8 greens engine, but 4x4, in the rain.So 2wd in the dry with 100 more bhp and you'd hit 7800 no probs!
7500 - 186
7800 - 194
8000 - 199
theres nothing that can slip to give a loose between the engine (revs) and the wheels
as gareth says, the gearing between engine and tyres is all fixed
if anything you will go faster, as the tyres grow
Wasn't rev counter, as it was being data logged (pectel monitor with Uncle Tony operating it at the time), and data logging showed 7600 rpm, as did the peak recall on the SPA rev counter.
Tyres were new Michelin Pilot Sports, but i reckon this is were the theory and reality times are decided, the tyres, different tyre companies have different rolling radius' for the same sized tyre, and they don't match the theoretical rolling radius.
for it Thread
Chris S
Jan 4, 2007 07:11 PM
Disabled Account
14
Oct 25, 2005 06:55 AM
Disabled Account
Jun 14, 2005 06:17 PM
