What settings for suspension?PLUS WANTED
Old Oct 1, 2006 | 05:07 PM
Default What settings for suspension?PLUS WANTED
The front has been lowered 30mm but the rear springs are std ride height. The springs are uprated by 30% loading...avo rear shocks and konis on front.....215/40/17 from 235/40/17 rear...Mike R rear shim mod.Poly bushed up front std bushes rear.
Now what settings for the avos on the rear there is loads of clicks on thje adjustment,what have you cossie owners got yours set to?..Also the front Konis not as much adjustment and no clicksjust abot 3 turns...what do i have it at for handling?
I need a steering joint as the rubber bit on mine is perished..the bit that joins the rack in the engine bay to a connection nest to the heater hoses.PM me if you got a new one for sale or any info.
Old Oct 1, 2006 | 09:32 PM
CosKev3's Avatar
CosKev3
See your post 'Just to update on Cossie..for those interested!!'
for info on steering coupling
Old Oct 2, 2006 | 01:37 PM
bttt
moesin2005
Jan 23, 2022 06:28 PM
dal3door
Aug 13, 2015 06:55 AM
Kevin_Mc
Aug 6, 2015 07:47 PM
adriansaleem
Aug 3, 2015 11:21 AM
Old ford
Jul 31, 2015 06:50 AM
