digital speedo ( HELP NEEDED)
Old Oct 1, 2006 | 01:10 PM
rsturbowhite's Avatar
rsturbowhite
Default digital speedo ( HELP NEEDED)
am looking for help to fit digiatal clocks to my track car , the gearbox is from a ford and has the sensors in to put the wiring too , just not sure wot else i need to make this happen , ie i no that i need a set off clocks but from wot car ,do i have to use the clocks from the same type off car the gearbox came from ?
are astra gte clocks the best cars to get clocks from or is ther some other cars that have digital clocks that are better to use (less wires ?)
can i just buy a kit, ie wireing already to plug up to clocks and gearbox as an not sure how the wireing and sensor calibrate too speed
Old Oct 1, 2006 | 09:57 PM
rsturbowhite
help some one
Old Oct 1, 2006 | 11:02 PM
jon@work's Avatar
jon@work
How do you expect anyone to be able to help you if you don't know what you want to do ?
If you'd asked "I want to fit an Astra GTE digi dash into my car - is there a straightforward wiring conversion loom available from anywhere, or does anyone know how to fit one ?" then someone may have helped you.
But you didn't.
So go and buy a Stack ST8000 - all instructions included.
Old Oct 1, 2006 | 11:09 PM
xrchris's Avatar
xrchris
by chance is there a conversion for gte clocks? wiring could probly be figured out but dunno if i could fit the transducer in the ford box
Old Oct 2, 2006 | 09:05 PM
rsturbowhite
jon@work
rsturbowhite
jon@work
wot part of the post dont u under stand why bother posting a reply if all u want to do is take the piss ???? its help am after thanks
Old Oct 2, 2006 | 09:17 PM
Dicko&Vacant's Avatar
Dicko&Vacant
was that you earlier graham in the bus or your kid couldnt tell
and if you need any astra gte clocks let me know sarah's mate has a few sets.
Old Oct 2, 2006 | 09:19 PM
marco polo's Avatar
marco polo
get an SPA digi speedo
Old Oct 2, 2006 | 09:27 PM
nigel b's Avatar
nigel b
why not use wheel speed sensors for the mph input
all depends on what dash your going for
Old Oct 2, 2006 | 09:41 PM
rsturbowhite
it was me dicko working had
not sure wot clocks i need havent had much to do with new ford car , hear focus have digi clocks
nigel b
the gearbox has the sensors all ther just not sure , how to wire them up , and to wot
maro polo
have u more info on the spa item as am blind to this
Old Oct 5, 2006 | 05:16 PM
rsturbowhite
just a bump up to the front again a real need to find info to make speedo work in car !
Old Oct 8, 2006 | 10:34 PM
marco polo's Avatar
marco polo
nigel b
maro polo
Hi mate
don't if you like it or not
http://www.spa-uk.co.uk/design/speedo.asp
or this
http://www.spa-uk.co.uk/design/dashsystem.asp
there you go
Marco
Old Oct 21, 2006 | 08:15 PM
rsturbowhite
marco
thanks for the post havent bin on the site for couple of weeks me ring them , very good info
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
col93saphcos
Aug 7, 2015 03:21 PM
Tinshaw
Aug 4, 2015 09:16 PM
Escortdriver1
Jul 31, 2015 02:36 PM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
