T38 with external wastegate
Hello Board,
recently bought a nice cossie in good condition. Since power is never enough, i am thinking of upgrading the turbo.
Currently the setup is like this:
- 200 block
- T3 (std. turbo)
- greens
- RS500 intercooler
- breather kit
- std. cams
The car is already pretty fast
Friends say: get a t34.63 with greys, remap and you might get 380-400 hp....but since the quest is always more power, I am thinking of getting a T38.
What I have been told, for the setup i have now, only a T38 with external wastegate would be a good choice (better spool up etc.)...
So basically my questions are:
- will a T38 with external wastegate offer good driveability given the current setup ?
- if not: what extra must/needs to be changed, to get the driveability ?
Thx !
- 200 block
- T3 (std. turbo)
- greens
- RS500 intercooler
- breather kit
- std. cams
Thx !
Why the hell would you want a external wastegate on a t38 also a t38 on your set up is a bit ott mate a t34 with .48 housing will give you a nice quick spool up i have a t38 on mine with internal wastegate with siemans injectors etc etc should see around 450
The idea is to fit a turbo that can be used now...AND later on when I change more on the car...
So the question is: will it be driveable and what is the minimum that needs to be changed right now to get driveability ?...(the external wastegate should give that quicker spool up)...
May 31, 2016 09:28 PM
Aug 14, 2015 07:29 AM
