How do you adjust the mfi metering unit?
Old Sep 30, 2006 | 10:35 PM
scotty86d's Avatar
scotty86d
Default How do you adjust the mfi metering unit?
can you make the car run richer or leaner off the unit itself or is it contained in the ecu?
Old Oct 1, 2006 | 07:05 AM
Hrsturbo's Avatar
Hrsturbo
you can adjust the fuel pressure by removing the black unit on the side of the metering unit and turning a screw. so I have been told anyway!
Old Oct 1, 2006 | 08:31 AM
addiction's Avatar
addiction
there is a mixture adjustment screw in the metering unit but unless you have the equipment to check the mixture accurately? leave it to a tuner to adjust!! cos if you get it wrong it will end in tears
Old Oct 1, 2006 | 09:45 AM
Chris69's Avatar
Chris69
u can use a small allen key to change the mixture, clockwise is richer/ anti-clockwise is leaner.
there are a few guides on how to do it so try and find one of them
Old Oct 1, 2006 | 10:06 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
As above. There is NO WAY you can 'guess' it and get it right. I tried myself a few years ago and made a total mess of it. The car wouldn't even run after I had finished. The CO screw is so sensitive.
Old Oct 1, 2006 | 12:10 PM
sexr3i's Avatar
sexr3i
isn't it
indeed, a quarter turn is a lot! get it to an mot station and hook it up to their emmisions equipment when adjusting. we wait till the tester has a slot free and bung him a drink to use it for 10 mins.
Old Oct 2, 2006 | 08:21 PM
scotty86d's Avatar
scotty86d
car doesnt drive, thats the problem!!!difficult to start and just stalls. metering unit might be off a 1.9 and spoke to ian at power and he said that it might be worth trying a very tiny adjustment and see if it helps(then will drive to get it checked)
Old Oct 3, 2006 | 06:34 PM
davidnormanuk's Avatar
davidnormanuk
This is the method I used to get me to the garage.
http://www.escortrsturbo.co.uk/forum...0&#entry115248
Fezman1
Oct 2, 2015 01:22 PM
gingeRS
17
Oct 2, 2015 09:42 AM
Steve Escos
Oct 1, 2015 06:57 AM
