can you???
Old Sep 30, 2006 | 10:07 PM
SWIFTY's Avatar
SWIFTY
Default can you???
this might be another stupid qestion but can u powder coat a gearbox???
or will it break it???
is it best just to pait it.
i want it to look a bit diffrant when u look under car..
Old Oct 1, 2006 | 09:49 AM
DAN P's Avatar
DAN P
i would just paint it m8 give it a very good clean with a power washer then paint it
Old Oct 1, 2006 | 06:56 PM
cosrep's Avatar
cosrep
I've seen it done before but it had to be stripped down first and then the casing(s) are cleaned/polished in the normal way. The powder used should be a low bake temp powder the same thats supposed to be used when powder coating alloy wheels.
