t34 boost hose diameter
Old Sep 30, 2006 | 05:05 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Default t34 boost hose diameter
does anybody know? i need to make a hole in the inner wing for the boost hose im only running a t3 at the moment but i plan to upgrade to a t34
Old Sep 30, 2006 | 05:07 PM
abdr500's Avatar
abdr500
63 mate
Old Sep 30, 2006 | 05:09 PM
Disabled Account's Avatar
Disabled Account
It's 68 mm:
Old Sep 30, 2006 | 05:15 PM
Disabled Account
I'm not so sure now
Split the difference = 66mm (+/- 2mm)
Old Sep 30, 2006 | 05:20 PM
GARETH T's Avatar
GARETH T
but thats inside diameter and he would need to make the hole for the outside diameter
Old Sep 30, 2006 | 05:29 PM
Disabled Account
Actually, the size I quoted is for the air filter to turbo hose, and so it's not a "boost" hose as such
Retro Al is that the hose you mean?
Technically, the boost hoses are the turbo to intercooler and intercooler to throtle body hoses
Old Sep 30, 2006 | 05:41 PM
dave cos4x4's Avatar
dave cos4x4
like Gareth said, you will need the outer size of the hose so it will fit through the inner wing.
probably rub aswell so will need protecting.
Old Sep 30, 2006 | 06:55 PM
Retro Al's Avatar
Retro Al
RWD IS KING
yeah its the hose from turbo to airfilter
Old Sep 30, 2006 | 07:05 PM
Andreas's Avatar
Andreas
Hold on and I will pop down to the garage and measure one of the Roose kits ive got in stock.
Edited:
Bit hard to get an exact measurement as the hoses flex a bit but the outerdiameter is around 79-80mm for a Roose escos filter-turbo hose.
gcfcos
59
Oct 6, 2015 05:04 PM
Russ Payne
Sep 25, 2015 08:29 PM
