series 1 running gear price update engine sold
alright folks ive decided to abanden my xr2t project as i dont have a lot of spare time with my other series 1 restro on the go
i have a complete series one engine with 3i box,turbo,inlet manifold,alt,starter motor still attachedintercooler,fuel tank(series 1)fuel pump,complete lines to and from the pump,hoses,complete loom which i have seperated,standard ecus and a chipped ecus,a/f meter with kn,full exausht with twin 5 inch tail pipe various other parts which i have .
the i was told that the turbo was a stage 1 but i have no recipets for that but it did boost quite well the reg of the car is b255 ank the car is now scrapped my mate did put a new head gasket, water pump before he left the car in his garage
if you need anymore info give us a bell on 07841700530 cheers
not sure mate ill get the pics up tommorow
when i had a look at the chip it did say early escort rs turbo
when i put it in my car before it ran 16psi i put this chip in it and it went straight off my boost gauge (30 psi)
and it didnt back fire or pink it did chutter when i let off tho
was told that the amal vavle will need re jetting tho unless your running a bleed valve
and it didnt back fire or pink it did chutter when i let off tho was told that the amal vavle will need re jetting tho unless your running a bleed valve
Just that mine broke a piston ring and fitted new rings and its never been the same...... bit dear bud, guy on hear selling re-bored block and +0.5 new pistons and rings for Ł400
sorry fella rather sell the relay with the loom i might have another one sitting in my room ill let you know asap cheers one of the pins was broken but it ran perfectly when fitted on my series 1 running 16psi
all the way mate is was only on the single pin tho i think the colour was black and yellow you couls take the casing off and solider another connecter on i was gonna do this and keep it as a spare but it never faulted the car at al tho
so i left it as it was
