custom clutch mechanism
I've got a paddle clutch and because of its stiffness my clutch pedal keeps on failing
I've got a mk5 pedal fitted by the way for the adjustability.
Is there a custom, say metal machanism that can be bought from somewhere???
As the crappy plastic ford ratchet/cog doesn't seem to be up to the job
Originally Posted by addiction
i mean it could be the clutch cable dude! i have a paddle clutch and it was a bit heavy when fitted,then i changed the cable and it was sorted
i gotta change my ratchet now anyhow so i may get a new cable while i'm at it.
just wondering if there was anything visually amiss with your cable?
not visually no! but as soon as it was off the car you could feel the stiffness in it!
