What to do with the cossie over winter??
Old Sep 30, 2006 | 01:23 PM
PSL's Avatar
PSL
Default What to do with the cossie over winter??
This will be my first winter with the cossie. I only plan to take it out on very dry days to keep everything lubricated etc. Can anybody offer advice for things I should do to stop potential problems once next spring comes.
The car is garaged, and I currently leave it parked in gear with the handbrake off and a chuck against each tyre to stop it moving.
Anything else I should be doing???
Thanks in advance.
Old Sep 30, 2006 | 01:48 PM
Alvyn's Avatar
Alvyn
anything else you'll need to do??
yea drive the bloody thing
Old Sep 30, 2006 | 01:50 PM
R5FORD's Avatar
R5FORD
leave a a couple windows open slightly 2 stop mould
Dave Parker's Avatar
Dave Parker
buy battery conditioner
it will go flat in no time
Old Sep 30, 2006 | 01:52 PM
R5FORD's Avatar
R5FORD
pmsl start the engine regulary mate
Old Sep 30, 2006 | 01:57 PM
Fil's Avatar
Fil
ELASTIC BAND
yep wait for it to snow, then go out in it and find a large empty carpark
Old Sep 30, 2006 | 01:59 PM
R5FORD's Avatar
R5FORD
thats not fair, dont get snow in australia
Old Sep 30, 2006 | 06:26 PM
Gra's Avatar
Gra
sooooooo true, mines coming out as soon as thers snow
Old Sep 30, 2006 | 06:30 PM
neil andeRSon's Avatar
neil andeRSon
Old Sep 30, 2006 | 06:31 PM
Rhys's Avatar
Rhys
Wax Oil it!!
Old Sep 30, 2006 | 06:37 PM
RS500/364's Avatar
RS500/364
make sure the heater work mine failed in the safe when it was snowing in norwich last year fuck me that was cold
and drive it car dont need babysitting
change the part for wear not because there unused !!
Old Sep 30, 2006 | 06:40 PM
DENNIS's Avatar
DENNIS
my car gets put up over winter every year, i would get it on axel stands if ya can to stop the tyres deforming, but befor you do give it a good clean and wax, vac and then a small run to clear sitting water, get a battery conditioner and if you can get a dehumidifier ( worth there weight in gold for winter storage ) once or twice a month run it up to temp and run it slow in gear ( make sure it cant move and the wheels are off / off the ground ) and bring it on boost using the brakes..... it may sound a bit much but change the oil befor you put it back on the road and it will be as good as when you took it off....
best of luck
Old Sep 30, 2006 | 06:46 PM
tregmatt's Avatar
tregmatt
give it a good coat of wax to stop the frost geting at it put some airfreshener in side to stop it smelling of damp start the car once a week
and keep the battery charged if you are not going to use the car at all
by a battery conditioner it stops it going flat
Old Sep 30, 2006 | 08:34 PM
PSL's Avatar
PSL
best of luck
Thanks, this was the kind of stuff I was looking for
Old Sep 30, 2006 | 08:35 PM
PSL's Avatar
PSL
Again, thanks a lot mate
gcfcos
59
Oct 6, 2015 05:04 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
AJC
Oct 1, 2015 06:47 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Carlbacciochi
Sep 26, 2015 04:23 PM
