engine mounts, which are the best ones?
i know this has been covered before, but i can only remember it being for the yb, this one is aimed at the 24V V6 people
the car: 24V sierra 4x4
the problem: on hefty starts it tends to break the drivers side engine mount regularly
the solution: from people who have been there and done this, which mounts would you recommend?
i know i've heard of someone making home made ones from a block of ali and a bolt, but it'd rather buy some proper ones that will do the job rather than use a small file and a drill and pray it all holds together
cheers
cheers
track.focus'd
Aug 12, 2015 05:53 PM
lockie
Jul 31, 2015 10:03 PM
