3dr Gearbox mount??
Cheers Stu. I did see that one. Also saw another one on flee-bay machined from solid billet alloy with no rubber claiming to be a rally spec... Has anyone heard of these before? Good? Still trying to make my mind up...
Cheers guys
Cheers guys
Yeah I saw that one as well but imo it would be a odd idea to have, with the engine moving and the gearbox not thru being bolted up rigid? Any1 else tried these??
Personaly i'd go for the uprated rubber jobby....at least its got some give to work in conjunction with the front engine mounts.
Stu.
Stu.
Guys I pulled mine to bits last weekend to find that the all alloy one is actually just he mount that bolts to the g/box itself. The rubber part sits up against that. It is actually just a "craddle" for the rubber mount itself. Couldnt imagine breaking the original one as it is cast. I would have thought the rubber would go first... as mine has done!!
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
