Quick question about painting.
Few of you might have seen I've been painting my new Morettes. I've got a thread in restorations for it. Need to know though how long after painting can I rub the runs down?
Sorry for starting another thread just worried I might need to rub the runs that have happened now than later on?
How soon should I rub them out and spray over?
Are you spraying from cans?
Or two pack??
If you need any other paint advice, See this thread
https://passionford.com/forum/viewto...light=spraying
Or two pack??
Cans are ok to flat down within the hour, if its touch dry, then use a very light wet 'n' dry
about 400/600 grit
If the paint starts to 'roll' stop and leave it, dont try and make it better, Leave it another hour
about 400/600 grit
Thanks,
Just rubbed one down with 1500 and its got rid of all the peel. However its exposed some primer in places, not bothered really will just make the next coat go on super smooth. HOPEFULLY.
SMILER258
Sep 28, 2015 09:04 AM
