any one no the high ohm equivelent to an 803 injector
Sep 27, 2006 | 10:32 AM
cheers if any one can help need them for a omex 500 system
Sep 27, 2006 | 11:01 AM
Sep 27, 2006 | 11:02 AM
yes i do,,, ill look it up now
Sep 27, 2006 | 11:03 AM
Hi matey
Cant you just run 803s with resistors? I may be talking through my arse on this.
JJ
Sep 27, 2006 | 11:07 AM
0280155766
i got a set here aswell
2000 miles old,,, never run over 60% duty
Sep 27, 2006 | 11:09 AM
I ran 803's on my Omex 500 with resistors.
Sep 27, 2006 | 11:11 AM
Quote:
why run resistors if you dont have too though?
Sep 27, 2006 | 11:13 AM
was going to run resisters but omex have said they had problems with missfires and 4 the sake of a few quid iv gota buy some proper ones.
What r these ones about 0280155766
cheers
Got to agree with this - far better to have the right injectors than compromise with resistors
JJ
Sep 27, 2006 | 11:16 AM
cheers
350cc injectors
Sep 27, 2006 | 11:19 AM
JJ
peak and hold injector drivers are totally different to a high impendance driver!
so the resistance might be right,,, but the driver isnt
Sep 27, 2006 | 11:25 AM
Yes, which is why I no longer have them. That said, I don't have Omex 500 any more either!
Sep 27, 2006 | 11:27 AM
Sep 27, 2006 | 05:10 PM
Sep 27, 2006 | 05:58 PM
Sep 27, 2006 | 06:03 PM
Sep 27, 2006 | 06:04 PM
Gareth will they fit ok to a cossie?
Sep 27, 2006 | 06:06 PM
Get some late 90's rover 2lt ones, they flow about 380cc for some odd reason. I could dig what was written on mine out later if required.
Sep 27, 2006 | 06:54 PM
pmsl @ gareth's ad...
Are they the ones like I had of you G? If so then they are exactly the same length fitment as the standard Bosch (eg 803) pattern injectors and will fit in place directly.
Sep 27, 2006 | 07:07 PM
yes mate,, they are the same as i gave you
Sep 27, 2006 | 08:26 PM
pm throttlebodiedzetecturbo he should be able to help you out
Oct 3, 2006 | 09:14 AM
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180033165493
these look ok for you
they do look ok dont they gareth
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
