uprated top engine mount??
Old Sep 26, 2006 | 12:56 AM
keo_rsturbo's Avatar
keo_rsturbo
Default uprated top engine mount??
does anyone have an uprated top engine mount i have the two gear box mounts uprated and the standard top one is shot?
does anyone actually make them???
Old Sep 26, 2006 | 08:30 AM
scotty86d's Avatar
scotty86d
second this. deflex are experimenting atm but cant find anyone else.
what do the big boy cvh's use?
Old Sep 26, 2006 | 09:23 AM
craig rs's Avatar
craig rs
dosent vibratechnics do um, i know they do the bottom mounts but dunno bout the top one
Old Sep 26, 2006 | 01:58 PM
Rick's Avatar
Rick
its just a hanger, std ones are fine
Old Sep 26, 2006 | 02:41 PM
davidnormanuk's Avatar
davidnormanuk
To be honest I'd use standard engine mounts as they seem to last the longest.
Old Sep 26, 2006 | 02:48 PM
John Laverick's Avatar
John Laverick
Has anyone ever had a top mout go? I've certainly never heard of it in 6 years of RST ownership!
Standard is the way to go!
Old Sep 26, 2006 | 03:30 PM
gus's Avatar
gus
standard on mine
Old Sep 26, 2006 | 03:50 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Standard on mine too!!
Let's wait until the big CVH boy's get here though!!
Old Sep 26, 2006 | 03:57 PM
gus's Avatar
gus
can you still get these new thou
mine isnt that old but would rather put a new one on
Old Sep 26, 2006 | 04:50 PM
Christian and Beccy
#1 in Spelling Club
Mine was replaced from Ford around 18 months ago.
Old Sep 26, 2006 | 05:15 PM
gus's Avatar
gus
cheers mr c
Old Sep 26, 2006 | 07:00 PM
Šhatter Box's Avatar
Šhatter Box
vibratechnics for ur gear box ford for ur engine mount
Old Sep 27, 2006 | 12:42 AM
keo_rsturbo
mine kind of went my inlet put a dent in my strut brace when i hit the power i will put some pics on tomorrow
Old Sep 27, 2006 | 08:14 AM
John Laverick
What kind of strut brace and what kind of inlet? [Is it EFi?]
Its probably your gearbox mounts that have gone rather than the engine mount if you're using the standard inlet.
Old Sep 27, 2006 | 08:28 PM
keo_rsturbo
i have a omp alloy strut brace and mfi
Old Sep 27, 2006 | 08:34 PM
John Laverick
Ah right, I'd still change your gearbox mounts first.....unless you've already changed them?
Old Sep 28, 2006 | 12:15 AM
keo_rsturbo
actully someone gave me a vibratech mount, can i put it on the front or the back? if i can where will i benifit from the most?
Old Sep 28, 2006 | 08:21 AM
John Laverick
It should fit front or rear [the standard ones do anyway]....depends which bush is knackered as to where to fit it.
You could always pick up a pair of good second hand ones brom a breakers on here.
I'd do it quickly as the next thing to go will be your exhaust downpipe!
RUBY123
Oct 22, 2023 12:04 PM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
lockie
Jul 31, 2015 10:03 PM
