Best alloy rad
hello maties
who makes the best alloy rad? cause I, like many others, I have S2 with a heating problem.. so this winter I will buy me a alloy rad to get the temps down..
were told that some alloy rad have double core... could someone please explain this to me
cheers
cheers
I talked to 1tub a FF06 and he had fitted a alloy on his S1 and it helped him with the temps.. but again not 2 cars are the same..
I have tried all the little trick. with the 82 degress termostat and cossie fan swiths.. I had 2 x 8" kenlowes... but still.. is playing with me...
craig rs: I think in your case its du to the cut out bumber.... My bird just hit a cat a couple of hours ago in my RSt..
so the next bumber I will fit, will also be cut out.. so we'll se if that does the trick on my car
No, its not because of that atall!!
I have a practically standard pre '90 spec bumper, GRS cooler, 2 fans, standard rad and an 82deg Stat and NO cooling problems!!
Forget Alloy rads, get a proper OE spec radiator.
Originally Posted by RS-adam
hello maties
cheers
cheers
I doubt you'd get much benefit from an alloy rad unless you're running massive spec and your rad is blocked off by a huge FMIC.
An alloy rad may not help reduce temps but surely its a better quality item than the standard ford item so surely if you can afford one and your due for a replacement, wouldn't it be best to buy an alloy rad?
Look at the spec of mine and it still runs a standard rad that I had recored about 3-years ago.
