Saff panels and parts???
Old Sep 23, 2006 | 11:46 PM
cosrep's Avatar
cosrep
Default Saff panels and parts???
I need a few parts for the rebuild I'm doing soon can anyone tell me if the following parts are still available spurious or OE
1. Driver side front wing?
2. Passenger side sill?
3. Front and rear wheel bearings?
4. Replacement joints for the front shaft - the new type that have the
grease nipples?
5. Side Indicators?
6. Windscreen washer jets?
7. Fitting kit for sideskirts?
Old Sep 24, 2006 | 10:44 AM
foreigneRS's Avatar
foreigneRS
Testing the future
1) yes. from either ford or aftermarket. i bought one from ford recently. i would always go oe if poss, as they're a better fit. they may say not available anymore, or v. expensive. in that case, you can use a std one, as the only difference is the holes in the bottom rear where the side skirt holder rivets on
2) don't know
3) yes, either oe or a/m
4) don't know
5) ? what do you mean? the sidelight is just a bulb in the main headlight
6) don't know, but plenty in scrap yards
7) yes, oe only. there are 3 different brackets down each side that must be ordered separately in the right quantities. there is no kit of parts for one side. they are expensive, and difficult to fi without breaking. tip - warm them up with a hot air gun first
Old Sep 25, 2006 | 03:17 PM
steventoon's Avatar
steventoon
6. yes
155lee
Sep 6, 2016 11:10 AM
dirty-diesel
Oct 3, 2015 08:00 PM
IainRS1700T
Sep 25, 2015 06:44 AM
chowfornow
Sep 19, 2015 10:47 PM
