Electric sunroof
Hi all
As above really. I need the sunroof glass and mechanism (the bit that goes in the roof). It needs to be in good working order and complete.
I dont need the electric motor or button etc. but if you dont want to split the bits, let me know, I may be tempted into buying for spares.
I would prefer to collect and buy in person, and I am also happy to remove myself if you are not sure. I am in the westcountry, so anywhere local would be even better!!
I also need a headlining ,as mine is particularly grubby
Thanks in advance
JJ
Thanks in advance
JJ
use a motor from a mk 3 granada as the spline fits onto a standard mech
remove relay as this gets in the way of cover,u will need some longer m6 bolts and thicker m6 washers to space the motor down a bit .
If thats what u want to do(have an electric one)
as for headlining warn water with washing powder clean cloth works a treat mine was really bad
remove relay as this gets in the way of cover,u will need some longer m6 bolts and thicker m6 washers to space the motor down a bit .If thats what u want to do(have an electric one)
