Anyone got the part number for the t3 drain pipe
do you mean the oil return pipe?
or do you mean the drain pipe for when you flush the turbo after a hard run?
don't have the part number but its cheaper to get one from Roose Motorsport 01522 787187 than Ford and you will get a silicone one that will last for ever and ever.
dont mean to hijack the thread but the roose sport oil return hose is silicone? thought ford made them out of the harder rubber for a reason then put those gay clips on it? if i get the silicone one can i just use jubilee clips to hold it on or will it crack aswell like the standard one on my car now? btw i never fitted the hose the geeza that owned it before me did.
chris
chris
Originally Posted by dave_y
the roose hose is silicone with fluoro oil resistant lining.
i use jubilee clips on mine and its been fine
never use jubilee clips as it will rip the hose use the clips like your meant to
it was about 10 pounds about 4 years ago
when i took the old rubber hose off, it was held on by jubilee clips.
i cant see the jubilee clips ripping the silicone hose. its about 4 times as thick as the standard hose.
