rear windows
right i need to remove my fixed rear windows to paint the car then fit them again after its done but im not having any luck, so can somone tell my a simple easy to understand step by step of how to do it and in reverse cheeRS in advance
alright mate, its pretty simple to do, you need a tool like a flat head screw driver but ideally something plastic so i doesnt damage anything. i use a plastic trim tool but i guess a plastic bicycle tyre remover tool will do or something along those lines.
start off on the inside top corner of the glass and carefully start to push the rubber under the metal flange. keep working your way along untill you feel it can be lifted out. just be careful not to force it.
putting it back in is a bit harder, you need a length of thin rope or really strong string. put the rubber on the glass, thread the string around the inside of the rubber, starting in the middle at the bottom all the way round then slightly over lap the ends back in the middle. you need a hand full left over at each end of the string.
place the bottom of the glass back in. now while holding the outside with one hand, putting pressure on it, pull the the string into the car working your way around the rubber. taking care to make sure that its pulling the rubber back over the metal flange.
if you can get some spray rubber lube, it will help it slot in nicely.
goodluck fella, its easier than it sounds
just lie on the back seats and put your feet against the top corner of the glass and push,it will pop straight out!
use thin string around the seal until they meet to put them back in. also helps to use silicone grease on the corners
155lee
Sep 6, 2016 11:10 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
