Fiesta RS1800 16v Turbo!
1995 FIESTA RS1800 16v Turbo!
ENGINE
2.1 Litre Zetec 16v,
Full AVA Turbo conversion,
MTX 2000 Stand alone ECU with internal laptop port and full diagnostic systems,
Garret T35 Hybrid Turbo,
Bailey Twin piston Dump valve,
8 Injectors,
Newman cams,
Ported, polished and skimmed head,
Wire ringed block with up-rated pistons, con rods, valves, valve seat stems and springs,
Lowered compression,
Direct port 150bhp Nitrous Express kit,
2way Nitrous delivery control,
Quaife 5 Speed straight cut gearbox with longer final drive and LSD,
Shortshift gear lever,
Battery relocated to boot space,
AVA Custom built intercooler,
Aqua mist cooler,
Loads more spec not enough space!
Performance
Documented 245bhp @ 5400rpm (without NOS)
Documented 312bhp @ 5400rpm (with NOS)
All figures taken At The Wheels
Holds 23psi of boost
ENGINE
8 Injectors,
Newman cams,
Aqua mist cooler,
Performance
thanks for the reply's folk!
to date i've spent £38,500 on buyin and building the car! this has been since august 1998 when i bought the car for the only reason to keep it in storage and build it to a massive spec.
finally got it finished and hoping to tag along and see the crowd at AVA on the 24th.
My S3 and most other cars dont have a look in with the Fez. My S3 is runnin 269bhp through the 4wheel drive and the Fez wipes the floor with it!
had loadsa fun in the car and so far on the dry roads its eaten these big hitters.... a Scooby WRX STi, a tuned EvoVII and a porche carrera S.!!
Tidy!! lol
Tidy!! lol
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
Matt Baxter
Sep 16, 2015 08:30 PM
paceo
Aug 27, 2015 12:45 PM
