bhp gain on gas flowed head
Old Sep 16, 2006 | 12:27 AM
Maxxeh's Avatar
Maxxeh
Default bhp gain on gas flowed head
wat gains wud i get?
Old Sep 16, 2006 | 07:08 AM
steven botes's Avatar
steven botes
gains would be minimal unless you are really going all out.
if you are not gong all out , at least ensure that your ports are lined up and make your own gaskets that fit properly.
When i was still using my dellorto 40 dhla's , i had ported the intake manifold into the head so the intake ports were almost the same size as the carbs - i gained response low down and stop cavitating with my T34 in mid range cruising
Old Sep 16, 2006 | 09:23 AM
LEE-RS's Avatar
LEE-RS
Custom
depends on who does the porting ive seen heads flow worse than standard
a good ported head should give +30 bhp on a standard engine the more boost you use the higher the gains
Old Sep 17, 2006 | 09:21 PM
stuart collins's Avatar
stuart collins
depends on wat the engine spec is already, with the right cam and set up could gain up to 40-50bhp
Old Sep 18, 2006 | 01:32 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
It's far too hard to generalise, but by porting the head, you will lose peak torque, so unless you have a turbo that can blow hard enough, the engine will lose it's punchy feel.
Depends on how you drive it.
I made 290lb/ft on a standard head at 250bhp, it was a gearbox breaker. Once the head was ported, peak torque dropped to 250lb/ft, but it felt stronger through the rev-range. If you don't have at least a stage 3 turbo, don't bother IMO.
Old Sep 19, 2006 | 09:14 PM
Rick's Avatar
Rick
personally, i think C is talking balls
Old Sep 20, 2006 | 09:28 AM
biglee's Avatar
biglee
Audio specialist
i saw 25hp on mine when it was done,
std cam, port matched,flowed,and big valves...
much more tourque aswell,
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
gavt123
Sep 5, 2015 10:03 AM
