SPA Gauges & Wiring ????
Post Miester !
I have had a SPA Dual gauge in the cossie since i have owned it, but i only ever
use it for boost, but i did not realise you could use it for so many things
Its a Boost and Temp One...
I have downloaded the manual from their website, but where and how do i wire in the
other sensors, say for the charge tempreture ??
Also who supplies these gauges ? so i can have a chat about gettin the sensors.
Ta...
Al....
Ta...
Al....
For the charge temp you will have to fit the sensor after the intercooler
Mine is going in the ally, top of the cooler just before the exit hose.
Its only a case of drilling & tapping - the sensor then threads in & maybe some sealing compound.
As long as you have the instruction manual its easy enough to program
Post Miester !
I was hoping i could wire it up for say charge tempreture..
I know how to get it on the dual setting, but i dont think the sensor is there,
where you i get one from ??
Options are as follows
All Results for
Filter By Brand... SPA DESIGN Order By... Price (Low to High) Price (High to Low) Name (A - Z) Name (Z - A)
« Prev 12 Next »Found 34 Products Showing 1-30 Show All
SPA DESIGN
Stepper Motor Analogue GaugesFrom £92.00
More Info
SPA DESIGN
Thermocouple Options For Dual Display GaugesFrom £20.60
More Info
SPA DESIGN
Boost/Fuel Pressure Series 2 Dual GaugeFrom £202.85
More Info
SPA DESIGN
Boost/Oil Temperature Series 2 Dual GaugeFrom £202.85
More Info
SPA DESIGN
Oil Pressure/Water Temperature Series 2 Dual GaugeFrom £133.69
More Info
SPA DESIGN
Oil Pressure/Oil Temperature Series 2 Dual GaugeFrom £133.69
More Info
SPA DESIGN
Fuel Pressure/Water Temperature Series 2 Dual GaugeFrom £133.69
More Info
SPA DESIGN
Oil Temperature/Water Temperature Series 2 Dual GaugeFrom £133.69
More Info
SPA DESIGN
Volts/Water Temperature Series 2 Dual GaugeFrom £133.69
More Info
SPA DESIGN
Boost/Temperature Series 2 Dual GaugeFrom £133.69
More Info
SPA DESIGN
Fuel Pressure/Volts Series 2 Dual GaugeFrom £133.69
More Info
SPA DESIGN
Oil Pressure/Volts Series 2 Dual GaugeFrom £133.69
More Info
SPA DESIGN
Oil Temperature/Oil Temperature Series 2 Dual GaugeFrom £133.69
More Info
SPA DESIGN
Temperature/Temperature Series 2 Dual GaugeFrom £133.69
More Info
SPA DESIGN
Boost/Exhaust Gas Temperature Series 2 Dual GaugeFrom £266.82
More Info
SPA DESIGN
Fuel Pressure/Oil Temperature Series 2 Dual GaugeFrom £133.69
More Info
SPA DESIGN
Pressure/Temperature Series 2 Dual GaugeFrom £133.69
More Info
SPA DESIGN
Transmission Temperature/Rear-End Temperature Series 2 Dual GaugeFrom £133.69
More Info
SPA DESIGN
Fuel Pressure/Oil Pressure Series 2 Dual GaugeFrom £202.85
More Info
SPA DESIGN
Fuel Level/Volts Series 2 Dual Gauge£185.09
More Info
SPA DESIGN
Hand Held Brake Bias Gauge£342.60
More Info
SPA DESIGN
Exhaust Gas Temperature Series 2 Dual Display Gauge£344.55
More Info
SPA DESIGN
SPA DashFrom £781.66
More Info
SPA DESIGN
Spares for Digital Speedometer GaugeFrom £3.37
More Info
SPA DESIGN
Combined Feature Tachometer and Boost GaugeFrom £359.95
More Info
SPA DESIGN
Combined Feature Tachometer And Digital Tachometer GaugeFrom £238.82
More Info
SPA DESIGN
Hand Held Tyre Temperature GaugeFrom £30.00
More Info
SPA DESIGN
Brake Bias GaugeFrom £249.60
More Info
SPA DESIGN
Digital Speedometer Gauge£162.56
More Info
SPA DESIGN
Hand Held ExtinguishersFrom £43.64
More Info
All Results for
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
SPA DESIGN
More Info
Demon Thieves supply these but why not try SPA direct.
i called them last week for instructions on the fuel gauge & they were very helpful
Not sure if they supply direct to the public though
Best make sure your wireing hasn`t been choped before ordering anything though
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
